app_clid_authen_col_npw.tcl
Answered Question
Jun 7th, 2007
  • Bronze, 100 points or more
Hi to everyone.
I need help with making app_clid_authen_col_npw.tcl (TCL Script version 2.0 - 2.1 ) work on my pots dial-peer. I want(need) an outside PBX to get internal dial-tone and then a possibility to dial DNs. A pots dial-peer was created and when I try to apply app_clid_authen_col_npw.tcl application no "application" command in dial-peer config.IOS version is 12.4(11)T1 (AS 5350).Insted of it I have a "service" command. Do someone can suggest a nice manual how to make a TCL script work or how to implement something similar to Direct Inward System Access.
Correct Answer by paolo bevilacqua about 10 years 2 weeks ago
How do you connect PBX to router? For example if PRI, you need to configure "isdn protocol-emulate network". Then for example if you dial 444 from PBX to get to router, your DP will be like:
dial-peer voice 400 pots
incoming called-number 444
And nothing else, that should give you dialtone from router.
Overall Rating: 4.5 (2 ratings)
paolo bevilacqua Fri, 06/08/2007 - 01:47
  • Hall of Fame,
    Founding Member
if all you want is a dial-tone from router, you don't need a TCL script. In fact by default the router behaves this way, that is, as long there no "direct-inward-dial" statement in the incoming dial-peer.
Volodymyr Morskyy Fri, 06/08/2007 - 02:57
Thanks for the answer.But it seems it doesn't work.Once again: I have an AS5350 and CM.I want calls from external PBX come not on hunt pilot(and then with broadcast or top down algoritm on users) but just get a dial-tone and then dial a required number. What should be configured on incoming POTS dial-peer?Or any suggestions how to do it with the means of TCL scripts?
PS: will rate your answer with great pleasure if it helps me.
Correct Answer
paolo bevilacqua Fri, 06/08/2007 - 05:53
  • Hall of Fame,
    Founding Member
Volodymyr Morskyy Sun, 06/10/2007 - 23:18
Thanks,p.bevilacqua it really works.(refusing from "direct-inward-dial" statement in incoming dial-peer)
