Parameterized Templates
Jun 7th, 2007
I am creating a user defined netconfig job with a parameterized template to change a number or variables on approx 800 cisco devices.
Is there a list anywhere of the correct values for the 'CMDPARAM NAME' field which I need to create in the file ?
e.g.
<CMDPARAM NAME = enable secret>
Or where can I find the correct syntax for the CMDPARAM NAME to change the following variables:
service password-encryption
enable secret password
snmp community strings
snmp server host address & string
Telnet, console & aux passwords?
With service password-encryption, how would this be written in a parameterized template i.e
<DEVICE NAME = 10.10.10.10>
<CMDPARAM NAME = service password encryption>
<value>??????</value>
</CMDPARAM>
If I wanted to turn service password encryption on using the template, what would the <value> field be?
Joe Clarke Fri, 06/08/2007 - 05:50
With parameterized templates, you are assigning commands to variable names. The idea with that is allow one to create a general template that has some device-specific components. Typically, these include things like hostname, IP addresses, ACLs, etc. But you can do this with "service password encryption".
To do what you want to do, pick a variable to represent "service password encryption" (e.g. $encryption). Your template will look like:
$encryption
And the XML file will look like:
