6509-E. SUP720 failure causes a linecard to powerdown
Jun 8th, 2007
Hi All,
Anyone seen this or experienced this before.
The equipment is a Cisco 6509-E switch running sup-bootdisk:s72033-entservicesk9_wan-mz.122-18.SXF6.bin code.
We have dual SUP720-3B's and 3x WS-X6748-GE-TX linecards.
We had a failure of the standby SUP720 which took down only one of the linecards. Linecard showed status as "PwrDown"
Is this a case of:
1. The SUP720-3B simply failed and requires replacement, as does the linecard it took down with it? OR
2. Is there something else going on here.
The failed SUP720 and linecarad was removed and reseated with no luck.
Here is some output from the logs attached in the txt file. Also output from a "show module"
ariela Fri, 06/08/2007 - 02:14
  • Silver, 250 points or more
first of all, try the last release: 12.2(18)SXF9.
At the same time, I'll investigate your issue.
Andrea
Andrew Morris Fri, 06/08/2007 - 02:35
Hi Andrea,
Trying to avoid a code upgrade for now until I know for certain that it is not some other identifiable problem that has been experienced by other forum members at some time.
Andrew Morris
kurtdeneef Fri, 07/04/2008 - 03:39
I have the same but with a GE-45AF linecard
s1-21141# show module
Mod Ports Card Type Model
Serial No.
1 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF
SAL1136ZPZ3
2 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF
SAL11370791
3 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF
SAL11370772
5 3 Supervisor Engine 32 10GE (Active) WS-SUP32-10GE-3B
SAL11370488
Mod MAC addresses Hw Fw Sw
Status
1 001d.4566.9400 to 001d.4566.942f 2.3 8.4(1) 8.5(0.46)RFW
Ok
2 001d.456e.4a30 to 001d.456e.4a5f 2.3 8.4(1) 8.5(0.46)RFW
Ok
3 001d.456e.44f0 to 001d.456e.451f 2.3 Unknown Unknown
PwrDown
5 001c.5834.532a to 001c.5834.532f 1.5 12.2(18r)SX2 12.2(18)SXF1
Ok
Mod Sub-Module Model Serial Hw
Status
1 IEEE Voice Daughter Card WS-F6K-48-AF SAL1137044C 2.3
Ok
2 IEEE Voice Daughter Card WS-F6K-48-AF SAL11370452 2.3
Ok
3 IEEE Voice Daughter Card WS-F6K-48-AF SAL1136ZVST 2.3
PwrDown
5 Policy Feature Card 3 WS-F6K-PFC3B SAL1136ZLLQ 2.3
Ok
5 Cat6k MSFC 2A daughterboard WS-F6K-MSFC2A SAL113703Z3 4.0
