ASA 5540 failover problem
Jun 8th, 2007
I've got a headache with the failover of 2 asa 5540 in master/standby configuration. I've already 2x 5520 in master/stanby and they are working OK.
The command sh fail on the 5540s shows:
Failover On
Failover unit Primary
Failover LAN Interface: failover GigabitEthernet0/2 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 3 of 250 maximum
Version: Ours 7.2(1), Mate 7.2(1)
Last Failover at: 15:51:36 CEDT May 24 2007
This host: Primary - Active
Active time: 3476085 (sec)
slot 0: ASA5540 hw/sw rev (1.1/7.2(1)) status (Up Sys)
Interface outside (x.x.x.x): Normal (Waiting)
Interface inside (y.y.y.y): Normal (Waiting)
Interface management (z.z.z.z): Normal (Not-Monitored)
Interface rtt (v.v.v.v): Normal (Waiting)
slot 1: empty
Other host: Secondary - Sync Config
Active time: 0 (sec)
Interface outside (x.x.x.x): Unknown
Interface inside (y.y.y.y): Unknown
Interface rtt (v.v.v.v): Unknown (Waiting)
slot 1: empty
Stateful Failover Logical Update Statistics
Link : failover GigabitEthernet0/2 (up)
Stateful Obj xmit xerr rcv rerr
General 0 0 0 0
sys cmd 0 0 0 0
up time 0 0 0 0
RPC services 0 0 0 0
TCP conn 0 0 0 0
UDP conn 0 0 0 0
ARP tbl 0 0 0 0
Xlate_Timeout 0 0 0 0
VPN IKE upd 0 0 0 0
VPN IPSEC upd 0 0 0 0
VPN CTCP upd 0 0 0 0
VPN SDI upd 0 0 0 0
VPN DHCP upd 0 0 0 0
Logical Update Queue Information
Cur Max Total
Recv Q: 0 0 0
Xmit Q: 0 0 0
On the secondary's console there's always comming out this message:
Detected an Active mate
Unable to sync configuration from Active
Changed ports and cables on switches and no luck.
Any suggestion please?
