CDR reports question
Hello, We are running CallManager and have CDR enabled. When i log into CAR and try and retrieve anything it gives me a 30061: Data is not available in database.
I thought i configured everything correctly on the servers.
Does CDR need to be enabled on both Publisher and Subscriber?
Greyson Morrow
Overall Rating: 5 (1 ratings)
mohammad.elshafie Thu, 02/21/2008 - 07:39
Please, I need your help,
The same error in CDR
"30061: data is not available in database"
happened to me in CCM ver 6.0
does anyone know how to solve it??
mohammad.elshafie Mon, 03/03/2008 - 02:24
Thanks so much it's worked now, although I had already activate the service for cdr, but i think that the main problem that I asked for a report and there is no data to be collected.
When I leave the site for about 10 days, now I can find the data and the error didn't appear again.
Thanks again for your help
shaqherath Tue, 05/27/2008 - 09:46
Thanks for the tip don.
I got most of it correct apart from going to ccm6 > System Parameters > CCMSERVER and then Select Cisco Callmanager Service.
Just set CDR enable flag to True
btw : I am running ccm6 new install
