cable based failover config on asa 5520
Jun 8th, 2007
hi,
we had 1 5520 & have purchased 1 new asa 5520. we want to make cable based active/active failover on this 2 devices. can someone help me with sample config? i found some docs but that were for pix. i need on asa.
acharyr123 Fri, 06/08/2007 - 04:27
could u please tell me my config is correct or wrong:
interface GigabitEthernet0/3
description STATE Failover Interface
failover
failover link failover GigabitEthernet0/3
failover interface ip failover 192.168.50.1 255.255.255.0 standby 192.168.50.2
acharyr123 Fri, 06/08/2007 - 04:48
can't active/standby filover be configured in asa in cable based failover mode?
cpembleton Fri, 06/08/2007 - 04:54
Your original post said Active/Active. Which one are you trying to do?
Chad
acharyr123 Fri, 06/08/2007 - 04:57
if i connect the 2nd asa in cable based failover mode, will the replication be done automatically? don't i need to specify the lan, wan side ip address also??
