DFM and eMail Notification
Jun 8th, 2007
I am attempting to get email notification working with DFM v1.2. I have editted the file mail_notify.conf as per the Cisco document explaining how to customize DFM to alert on specific alarms, but when I add more than one GA_Choice.... section mail delivery stops, I'm guessing my syntax is incorrect in the file, below is how I have the file configured currently, the first GA_Choic... section I want to be alerted when any router is unresponsive, the second is a catch all to see if I could get the syntax correct and after that was added I haven't been able to generate an email. Thanks for any help.
ReadsInputFrom = GA_SubscriberFE::mail_Notifier-Subscriber-FrontEnd
# How long an event must remain active before the adapter sends a
# notification, in units of seconds.
eventSmoothingInterval = 0
# Notification threshold; discard notifications with a certainty
# below this value.
minimumCertainty = 0.01
SubscribesTo =
GA_ChoiceSubscription::DeviceDownTest
className = "Router"
instanceName = ".*"
eventName = "Unresponsive"
problems = FALSE
aggregates = FALSE
symptoms = TRUE
GA_ChoiceSubscription::DeviceDownTest2
className = ".*"
instanceName = ".*"
problems = FALSE
aggregates = FALSE
symptoms = TRUE
Joe Clarke Fri, 06/08/2007 - 05:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It looks like you might have an additional '{' in there You don't need another '{' after the "}," from the first subscription.
