Traffic Flow
Jun 8th, 2007
I have a successfully setup a VPN connection through Cisco PIX 506 (E) 6.3(5)
But certain HTTP traffic to port 8080 doesnt seems to pass.
How do i check where its getting blocked
How can i check which traffic is going through the VPN tunnel
acomiskey Fri, 06/08/2007 - 04:59
Are you trying a port translation in the firewall over the vpn? Something like this...
static (inside,outside) tcp 8080 80 netmask
If so are you then attempting over the vpn?
You can check which traffic is going over the tunnel by looking at the pix config or by the route statistics on the vpn client.
