Urgent help needed - unable to boot!
Jun 8th, 2007
I recently upgraded my IOS (3750), and everything was fine. Now though when I try to boot I get the following:
Base ethernet MAC Address:
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 3 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 6656
flashfs[0]: Bytes available: 15992320
flashfs[0]: flashfs fsck took 8 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c3750-ipbase-mz.122-25.SEE3.bin"...flash:c3750-ipbase-mz.122-25.S
EE3.bin: magic number mismatch: bad mzip file
Error loading "flash:c3750-ipbase-mz.122-25.SEE3.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
I guess it's corrupted...how can I get another image from tftp? The commands available now are very few.
Please help!
Thanks, J
Overall Rating: 5 (1 ratings)
Issue a break while trying to boot. Once you are in rommon check flash to get exact filename that is in there. Try boot flash:filename.
If this doesn't work, I am afraid you are stuck with an xmodem recover over the console port. Unfortunately this is a bit of a nightmare, as you are stuck with 9.6k a second transfer. For details on xmodem please see the attached link
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml#topic2
Hope this helps
Martin
jigsaw2026 Fri, 06/08/2007 - 07:20
Hi Martin,
Thanks very much for your response, much appreciated.
I am now doing an xmodem transfer.
J
