ASA5505 Newbie, T1 interface multiple public IPs
Answered Question
Jun 8th, 2007
I am trying to setup up our ASA5505 on our T1. I have outside interface setup on xx.xx.170.18 (the first open public IP). We want non encrypted SMTP traffic to flow from this IP to the mail server at 192.168.1.50. Then I want encrypted mail on our next available public ip xx.xx.170.20 to come into the ASA5505 and route to 192.168.1.30 via SMTP port 25 also. I am stumped though as to how to accomplish this. Do I need an additional "outside" interface for the other public ip? There is 1 T1 line can that "line" have 2 ip addresses?
Thanks for the help.
Correct Answer by acomiskey about 9 years 7 months ago
That's a lot of pressure, haha, but yes it looks fine.
device access -> aaa access -> check enable server group local and check ssh server group local
you should then be able to use the username you created in asa.
Overall Rating: 5 (2 ratings)
acomiskey Fri, 06/08/2007 - 07:23
The whole /29 network is routed to you by the isp so you do not need another physical interface. You just need to add another static and acl entry for the new server.
access-list out2in extended permit tcp any host xx.xx.170.20 eq smtp
static (inside,outside) xx.xx.170.20 192.168.1.30 netmask 255.255.255.255
thomas.estes Fri, 06/08/2007 - 07:31
Ok,
I am struggling with inputting these via the ASDM I always seem to get them backwards. So how do I telnet or SSH to the device so that I can CLI these commands to the device.
Again sorry to be such a newbie.
I try and access via telnet and I get:
User Access verification
PASSWORD:
When I try the password that I use for ASDM it does not work.
acomiskey Fri, 06/08/2007 - 07:35
Configuration -> Properties -> Device Access
Add your ip address or network you are on to ssh or telnet lists. I recommend ssh.
thomas.estes Fri, 06/08/2007 - 07:40
I did that and SSH times out (trying via PuTTY).
Telnet wants a password and I try the password that I use same password that I use for ASDM and no luck
acomiskey Fri, 06/08/2007 - 07:51
Try Config -> Properties -> Certificates -> Key pair
You should have a general purpose 1024 key there, if not hit add and generate now. Then try ssh.
check your config for
aaa authentication ssh console LOCAL
thomas.estes Fri, 06/08/2007 - 08:03
ok I generated the general purpose cert and can now get putty to connect via ssh but still can;t logon.
It asks logon as:
I have tried blank
I have tried enable_15
and a user id that I created to no avail.
Correct Answer
acomiskey Fri, 06/08/2007 - 08:08
thomas.estes Fri, 06/08/2007 - 08:11
that resolved my ssh access. thanks so much for your help. I will now try to apply these rules to fix my original issues.
thomas.estes Fri, 06/08/2007 - 10:11
If I use this then email flows in from the outside.
static (inside,outside) tcp interface 25 192.168.1.50 25 netmask 255.255.255.255 0 0
As soon as I change this to
static (inside,outside) xx.xx.170.18 192.168.1.50 netmask 255.255.255.255
mail flow stops.
I need to be able to point at the specific incoming IP so that I can route between x.x.x.18 smtp and x.x.x.20 smtp zixvpm.
any ideas?
acomiskey Fri, 06/08/2007 - 10:16
You said you wanted xx.xx.170.18 to map to 192.168.1.30....not 192.168.1.50.
Is that correct or no?
acomiskey Fri, 06/08/2007 - 10:21
Sorry, when the address is also your outside interface address and you are doing pat then you need to use the "interface" keyword in your static. Since xx.xx.172.18 = ASA outside interface address then...
static (inside,outside) interface 192.168.1.50 netmask 255.255.255.255
thomas.estes Fri, 06/08/2007 - 10:31
ok I have tried those.
Do I need to do the PAT here as well for the smtp?
Below is the new running config
Result of the command: "show running-config"
: Saved
ASA Version 7.2(2)
hostname ASA5505
domain-name amcinc.us
enable password 8aPd93D5bXaT2fFZ encrypted
names
interface Vlan1
mac-address 0012.3f7f.9876
nameif inside
security-level 100
interface Vlan2
description NuVox T1
nameif outside
security-level 0
ip address x.x.170.18 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns domain-lookup inside
dns server-group DefaultDNS
object-group icmp-type icmp_grp
icmp-object echo-reply
icmp-object information-reply
icmp-object traceroute
access-list out2in extended permit tcp any any eq smtp
access-list out2in extended permit tcp any host x.x.170.18 eq https
access-list out2in extended permit tcp any host x.x.170.18 eq 9850
access-list out2in extended permit tcp any any eq 1677
access-list out2in extended permit tcp any any eq 7205
access-list out2in extended permit icmp any any echo-reply
pager lines 24
logging enable
logging asdm informational
logging from-address [email protected]
logging recipient-address [email protected] level errors
logging host inside 192.168.1.114
logging permit-hostdown
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface https 192.168.1.50 https netmask 255.255.255.255
static (inside,outside) tcp interface 9850 192.168.1.50 9850 netmask 255.255.255.255
static (inside,outside) tcp interface 1677 192.168.1.50 1677 netmask 255.255.255.255
static (inside,outside) tcp interface 7205 192.168.1.50 7205 netmask 255.255.255.255
static (inside,outside) tcp interface smtp 192.168.1.50 smtp netmask 255.255.255.255
static (inside,outside) x.x.170.20 192.168.1.30 netmask 255.255.255.255
access-group out2in in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.170.17 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
username xxxx password pfaW5bAu431sHznu encrypted privilege 15
http server enable
http 192.168.1.0 255.255.255.0 inside
ssh 192.168.1.110 255.255.255.255 inside
ssh 192.168.1.114 255.255.255.255 inside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.100-192.168.1.149 inside
dhcpd dns 64.89.70.2 64.89.74.2 interface inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
webvpn
csd image disk0:/securedesktop-asa-3.1.1.29-k9.pkg
prompt hostname context
Cryptochecksum:1f035eed7192c5ef42cf50d5e477e8d3
: end
acomiskey Fri, 06/08/2007 - 10:35
This is pat...
and it has nothing to do with your smtp problem. Your config looks fine, .20 is not working or what? Try a "clear xlate".
acomiskey Fri, 06/08/2007 - 10:41
I think I told you this previously as well but you want to write your acl's to be more specific than any.
access-list out2in extended permit tcp any x.x.170.18 eq smtp
access-list out2in extended permit tcp any x.x.170.20 eq smtp
access-list out2in extended permit tcp any host x.x.170.18 eq 1677
access-list out2in extended permit tcp any host x.x.170.18 eq 7205
thomas.estes Fri, 06/08/2007 - 10:44
You had, I just have been so paranoid about email not flowing in that I did not want to change them.
acomiskey Fri, 06/08/2007 - 10:45
No probs, what you have in your config should work fine for the second smtp server.
thomas.estes Fri, 06/08/2007 - 10:59
Last time, (hopefully).
Since I am paranoid and skeptical.
Here is my config. that I hope will allow traffic from our 2 different public IPs to one interface both on port 25.
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
access-list out2in extended permit tcp any host x.x.170.18 eq smtp
access-list out2in extended permit tcp any host x.x.170.20 eq smtp
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
asdm history enable
arp timeout 14400
username xxxxx password pfaW5bAu431sHznu encrypted privilege 15
http server enable
http 192.168.1.114 255.255.255.255 inside
snmp-server host inside 192.168.1.1 community ASA5505
snmp-server location Data Room
snmp-server contact Tom Estes
snmp-server community ASA5505
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
webvpn
: end
Correct Answer
acomiskey Fri, 06/08/2007 - 11:02
thomas.estes Fri, 06/08/2007 - 11:05
Thank you so very much.
If you are ever any where near Ohio let me know and I will by you a round of drinks!
acomiskey Fri, 06/08/2007 - 11:07
Also, not to complicate matters but if you are not going to use .18 for anything other than 192.168.1.50 then you can remove all those statics and just do one..
no static (inside,outside) tcp interface https 192.168.1.50 https netmask 255.255.255.255
no static (inside,outside) tcp interface 9850 192.168.1.50 9850 netmask 255.255.255.255
no static (inside,outside) tcp interface 1677 192.168.1.50 1677 netmask 255.255.255.255
no static (inside,outside) tcp interface 7205 192.168.1.50 7205 netmask 255.255.255.255
no static (inside,outside) tcp interface smtp 192.168.1.50 smtp netmask 255.255.255.255
I just might..but I don't know if you'd be able to buy a steeler fan drinks.
thomas.estes Fri, 06/08/2007 - 11:14
kk
did that, below are teh results:
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
asdm history enable
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
webvpn
Cryptochecksum:aeb680ce0caab7808916b2340f8eee7a
: end
acomiskey Fri, 06/08/2007 - 11:16
Looks good, now if you need another port for .18, instead of adding another static like before, you just have to allow it in the acl. Looks much cleaner too. Enjoy.
thomas.estes Fri, 06/08/2007 - 11:24
Thanks again for all of your help.
One last question.
So that I am not relying on the kindness of strangers to help me and for my own edification can you recommend any good books that would cover my last couple of questions.
Thanks!
