CCNA: Erase Startup-Config vs Erase NVRAM
Jun 8th, 2007
For the purposes of the CCNA exam, it it a true statement that "erase startup-config" and "erase NVRAM" are equivalent?
The appear functionally equivalent, but I was wondering if the CCNA test will require you to know about any differences between them?
mohammedmahmoud Fri, 06/08/2007 - 09:50
The erase nvram: command replaced the write erase command and the erase startup-config command, and i don't think that the CCNA will alter this in details.
HTH, please do rate all helpful replies using the scroll box on the right,
Mohammed Mahmoud.
distraido Fri, 06/08/2007 - 16:38
Agreed...I still use "Write Erase" is all the same...just revised in newer IOS and some are considered old.
