ISDN BRI issue on Cisco 3825
Answered Question
Jun 8th, 2007
3825 with 2 x WIC-1B-S/T-V3 in Turkey. Not able to make ISDN calls from London. Calls answered, PPP authentication Ok but calls then immediately dropped. Router running IOS 12.3(14)T7 SP Services.
BRI i/f configuration:
interface BRI0/1/0
no ip address
encapsulation ppp
dialer pool-member 50 max-link 2
isdn switch-type basic-net3
isdn point-to-point-setup
ppp authentication chap
ppp multilink
Layer 2 not MULTIFRAME_ESTABLISHED, but TEI_ASSIGNED, not necessarily a problem:
Global ISDN Switchtype = basic-net3
ISDN BRI0/1/0 interface
dsl 2, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 70, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 2 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
Q.921 debug:
istfirtc01#clear int bri 0/1/0
istfirtc01#
Jun 8 18:27:45.858 GMT+3: ISDN BR0/1/0 Q921: User TX -> IDREQ ri=19513 ai=127
Jun 8 18:27:45.878 GMT+3: ISDN BR0/1/0 Q921: User RX <- IDASSN ri=19513 ai=71
Jun 8 18:27:45.878 GMT+3: ISDN BR0/1/0 Q921: L2_EstablishDataLink: sending SABME
Jun 8 18:27:45.878 GMT+3: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=71
Jun 8 18:27:45.886 GMT+3: ISDN BR0/1/0 Q921: User RX <- IDCKRQ ri=0 ai=127
Jun 8 18:27:45.886 GMT+3: ISDN BR0/1/0 Q921: User TX -> IDCKRP ri=4042 ai=71
Jun 8 18:27:45.894 GMT+3: ISDN BR0/1/0 Q921: User RX <- UAf sapi=0 tei=71
Jun 8 18:27:45.894 GMT+3: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI71 changed to up
Jun 8 18:27:46.878 GMT+3: ISDN BR0/1/0 Q921: User RX <- IDCKRQ ri=0 ai=127
Jun 8 18:27:46.878 GMT+3: ISDN BR0/1/0 Q921: User TX -> IDCKRP ri=3179 ai=71
Jun 8 18:27:47.878 GMT+3: ISDN BR0/1/0 Q921: User RX <- IDREM ri=0 ai=70
Jun 8 18:27:47.890 GMT+3: ISDN BR0/1/0 Q921: User RX <- IDREM ri=0 ai=70
Jun 8 18:27:55.894 GMT+3: ISDN BR0/1/0 Q921: User TX -> RRp sapi=0 tei=71 nr=0
Jun 8 18:27:55.910 GMT+3: ISDN BR0/1/0 Q921: User RX <- RRf sapi=0 tei=71 nr=0
Jun 8 18:28:02.254 GMT+3: ISDN BR0/1/0 Q921: User RX <- DISCp sapi=0 tei=71
Jun 8 18:28:02.254 GMT+3: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 71 changed to down
Jun 8 18:28:02.254 GMT+3: ISDN BR0/1/0 Q921: User TX -> UAf sapi=0 tei=71
Jun 8 18:28:30.959 GMT+3: ISDN BR0/2/0 Q921: User RX <- IDCKRQ ri=0 ai=127
Jun 8 18:28:30.959 GMT+3: ISDN BR0/2/0 Q921: User TX -> IDCKRP ri=54044 ai=77
Jun 8 18:28:31.959 GMT+3: ISDN BR0/2/0 Q921: User RX <- IDCKRQ ri=0 ai=127
Jun 8 18:28:31.959 GMT+3: ISDN BR0/2/0 Q921: User TX -> IDCKRP ri=1245 ai=77
When line moved to a 2610XM, ISDN calls Ok.
Correct Answer by paolo bevilacqua about 9 years 11 months ago
router is disconnecting the call:
Jun 8 18:33:15.965 GMT+3: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Cause i = 0x8090 - Normal call clearing
there are apparently no problem at ISDN level, please check again PPP negotiation. The only thing you can improve at ISDN layer, is "isdn tei-negotiation preserve".
Overall Rating: 4 (1 ratings)
herve.durand Fri, 06/08/2007 - 07:46
Q.931 debug:
Jun 8 18:33:13.869 GMT+3: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Calling Party Number i = 0x00C3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA1, '2123938154'
Plan:ISDN, Type:National
Low Layer Compat i = 0x8890
Sending Complete
Jun 8 18:33:13.873 GMT+3: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to up
Jun 8 18:33:13.873 GMT+3: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to N/A N/A
Jun 8 18:33:13.889 GMT+3: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI71 changed to up
Jun 8 18:33:13.889 GMT+3: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref =0x81
Channel ID i = 0x89
Jun 8 18:33:14.889 GMT+3: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref =0x81
Channel ID i = 0x89
Jun 8 18:33:14.909 GMT+3: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8 callref = 0x81
Jun 8 18:33:15.001 GMT+3: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8 callref= 0x01
Jun 8 18:33:15.961 GMT+3: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1 disconnected from bebek, call lasted 2 seconds
Jun 8 18:33:16.053 GMT+3: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
Jun 8 18:33:16.057 GMT+3: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to down
Jun 8 18:33:16.057 GMT+3: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
Jun 8 18:33:32.854 GMT+3: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 71 changed to down
Jun 8 18:33:32.854 GMT+3: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Everything points to a problem on the 3825. Any known issues with the WIC-1B-S/T-V3?
Many thanks.
Correct Answer
paolo bevilacqua Fri, 06/08/2007 - 08:40
  • Hall of Fame,
    Founding Member
herve.durand Mon, 06/11/2007 - 09:57
Well, even though the PPP debug showed that authentication succeeded, remving CHAP config (including username) and putting it back appears to have solved the problem.
Thanks for the hint.
paolo bevilacqua Mon, 06/11/2007 - 10:13
  • Hall of Fame,
    Founding Member
You're welcome, thanks for the nice rating and good luck!
