CCIE Training Lab
Jun 8th, 2007
I am setting up a training lab for my company that will be used by associates studying for CCNA up to CCIE. What devices do you recommend we set up at minimum and what would be ideal?
Thank you
Edison Ortiz Thu, 06/14/2007 - 07:48
9 routers and 4 switches. On the routers, get as many serial interfaces you can and they should have dual FastE/GigE.
The switches should be 3550 or 3560.
Purchase an additional cheap router to serve as Frame-Relay.
With those components, you can perform any lab from different vendors.
