DHCP Snooping
Jun 8th, 2007
I am setting up DHCP Snooping and I am looking at the configuration guide for the 6500 series switch. These are the steps that they show:
Step 1
Add DHCP snooping to the VACL.
set security acl ip acl_name permit dhcp-snooping
Step 2
Configure the VACL to allow DHCP snooping from all hosts.
set security acl ip acl_name permit ip any any
Step 3
Save the VACL.
commit security acl acl_name
Step 4
Add an ACL to a VLAN.
set security acl map acl_name 10
What I want to know is if I make this access list will the other "set security acl" entries that I already have be overwritten? Also, for the "ip permit any any", this will make it so that all the hosts are are bound by dhcp-snoop right?
royalblues Fri, 06/08/2007 - 11:38
  • Green, 3000 points or more
Since the named access-list used for snooping and security will be different, it will not be overwritten.
Access-list are not overwritten when you add statements but they just get appended at the end. You need to be careful while removing statements.
HTH, rate if it does
Narayan
