Correct Answer
mahmoodmkl Fri, 06/08/2007 - 11:50
I should be configured as a access port in the particular vlan according to u r design.
Mahmood
s.chaney Fri, 06/08/2007 - 11:55
I need to configure the port for access to the data vlan.
srue Fri, 06/08/2007 - 11:57
switchport access vlan xxx
you also might want to enable portfast, and hardcode speed/duplex.
speed 100
duplex full
spanning-tree portfast
(dont forget to hardcode speed/duplex on the firewall)
mahmoodmkl Sat, 06/09/2007 - 00:42
No,by giving this command u r making this port as a access port,but the vlan membership remains unkown.U need to define it in the vlan according to ur design.i.e the subnet which u r using for u r firewall.
By default the port will be in vlan 1.
Mahmood
