2950 ios upgrade from 12.0(5.3)WC(1)
Jun 8th, 2007
Are there interim releases to which I should upgrade before upgrading to current ios 12.1.22-EA10?
Overall Rating: 4 (1 ratings)
royalblues Fri, 06/08/2007 - 11:59
You can always upgrade the switch directly to the latest IOS without upgrading it first to any interim releases as long as your flash and DRAM requirements for the IOS fulfill
HTH, rate if it does
mohammedmahmoud Fri, 06/08/2007 - 12:14
Hi Narayan,
Sorry didn't see your reply on both posts, i was just reviewing unreplied posts.
Please do accept my apology :)
Mohammed Mahmoud.
royalblues Fri, 06/08/2007 - 12:20
No need to apologize buddy... it happens with everyone. sometimes you try to answer a query but by the time u post, u find a reply already..
All that matters is whether the query gets answered.
Lost ur mail ID.. can u resend it ..
mohammedmahmoud Fri, 06/08/2007 - 12:01
AFAIK, no you can go directly to the current IOS with no problems at all.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
