12.2(18)SXF and Catalyst 6513
royalblues Fri, 06/08/2007 - 12:05
yes it should..
BTW are you running Hybrid or Native?
If running bybrid, where did you issue this command
visurth130174 Sat, 06/09/2007 - 04:44
it supports ip routing...find out what are you running CatOS or IOS..?
in native mode the switch runns on IOS
in hybrid mode the switch is running CatOS on the sup and IOS on the MSFC card...check what is the sup eng you are running and the msfc type.
if you are planning to upgrade from hybrid to native plaes make sure to convert the configurations in to support IOS.
Here is the Show Version:
SW1_>show ver
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICES_WAN-VM), Version 12.2(18)SXF8, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Sat 03-Mar-07 01:58 by tinhuang
Image text-base: 0x01020150, data-base: 0x01021000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
PIPSCORESW1 uptime is 3 days, 17 hours, 30 minutes
Time since PIPSCORESW1 switched to active is 2 days, 23 hours, 8 minutes
System returned to ROM by Stateful Switchover (SP by reload)
System restarted at 14:08:04 EST Thu Jun 7 2007
System image file is "sup-bootdisk:s72033-ipservices_wan-vz.122-18.SXF8.bin"
cisco WS-C6513 (R7000) processor (revision 1.1) with 491520K/32768K bytes of memory.
Processor board ID SAL1113KBSF
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
4 Virtual Ethernet/IEEE 802.3 interfaces
244 Gigabit Ethernet/IEEE 802.3 interfaces
4 Ten Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
So with this, is this syystem running in Hybrid or Native mode?
If in Hybrid mode, what am I accessing when connecting to the console port?
And how do I access the other part?
royalblues Mon, 06/11/2007 - 04:06
As Mohammed said, you are connected to the RP nad hence you should be able to execute the ip routing command.
what error do you get when you try to issue the above command
