IP Communicator 2.0 _ Can't hear caller
Jun 8th, 2007
I have configured IP communicator as recommended. I tested it on my network and it works fine. I can place a call and hear the speaker and she could hear me. When I connect remotely through our VPN (Aventail), I can register IP Communicator but I cannot hear the caller and she could not hear me. Is there a setup or configuration option I forgot to enable?
Thank you.
Overall Rating: 4 (2 ratings)
Majdi Harb Fri, 06/08/2007 - 21:58
  • Silver, 250 points or more
i think the problem is with ur VPN (Aventail), since Supported software VPN clients include Cisco Systems VPN Client 3.x or 4.x, and the Microsoft PPTP client. Other third-party VPN clients might be unsupported.
a VPN solution is typically unsupported if it is not a Cisco product and does not function like a network interface card.
try using supported vpn client and check if it is solved?
hth
please rate helpful posts
Majdi
rrojas Sat, 06/09/2007 - 03:00
Thank you for the reply. I tested the VPN with other laptops using IP Communicator 2.0 and they work correctly.
Thank you.
mtahirkhan82 Tue, 06/12/2007 - 15:12
I am new in voip. i want to setup voip in lab. could you please suggest me which equiptment i should use. and also let me know about abour for voip carrier
Majdi Harb Wed, 06/13/2007 - 01:09
hi mtahirkhan82
so regarding Cisco Voip home lab for building knowledge and testing purposes and also walking the first step in this field without paying a lot of money mainly if u get the following items u can cover most of Cisco Callamanger-ip telephony configuration areas and really u will be able to design and implement a Cisco ip telephony project:
1: cisco callmanager 4.x virtual machine (VMWare), install it on any capable pc or server. if u could not get CCM VM files please let me know i can send u a link where u can download it.
2: cisco ip communicator (softphone installed on ur pc) or if u would like to work on physical ip phones, u have to buy cisco ip phones (note that it works without license for home lab purposes so don't worry about phones licensing). also to power ip phones u need either a poe switch or power adapter for each ip phone or even active patch panel (that gives power on 4,5,7,8 pins).
3: if u want to go outside (calls to pstn) in ur testings u have to buy a small series gateway (1700 is ok or start with 2800 ISR's series) download a voice grade ios. and a FXO card (say 2 ports PN: VIC2-2FXO), just plug it (RJ11) with ur telephone line box on the wall.
4: u have to start reading callmanager system and admin guides in addition to callmanager SRND.
hth
/majdi
mtahirkhan82 Wed, 06/13/2007 - 09:01
Thanks for nice information.
can you please send the link where from i can download cisco callmanager 4.x virtual machine (VMWare)
regards
m k
eng_hanymag Sat, 06/23/2007 - 23:51
Dear
Please any one help me that i have the same problem and i can't solve it untile now
