Telnet PIX from outside interface?
Jun 8th, 2007
telnet ip-address mask outside
Although it's not recommended but,
Will it work fine? ACL is allowed.
I want to access PIX remotely, is there any other config to do?
Can anyone help?
Jon Marshall Fri, 06/08/2007 - 14:50
No, you cannot telnet to the outside interface of the pix. You have 2 options
1) Set up an IPSEC tunnel to the pix for management
2) use ssh to access the firewall.
Note that you don't need an acl for this you need the following line in the config
ssh "ip address allowed" "netmask" outside
To set up ssh you need to make sure the pix has
1) hostname
2) domain name
then you need to generate rsa keys on the pix and then save them with the "ca save all" command. Just doing a wr mem will not save you rsa keys.
Jon
marko.rahne Mon, 06/11/2007 - 00:09
You can configure
management-access inside
and then telnet via VPN to inside interface
