L2TP over IPSec RA VPN not working
Jun 8th, 2007
I have been trying to get an L2TP over IPSec VPN using pre-shared keys working, but it just keeps failing with the same errors. For some reason it claims that it can't find a valid tunnel group. I am trying to connect using Windows XP VPN. The client is behind a nat, but I have already applied the NAT-T registry fix, but it didn't help.
Error:
Jun 08 2007 21:35:07: %ASA-6-302015: Built inbound UDP connection 129881 for outside:mail.companyname.net/500 (mail.companyname.net/500) to NP Identity Ifc:10.0.0.154/500 (10.0.0.154/500)
Jun 08 2007 21:35:07: %ASA-4-713903: Group = 192.168.29.2, IP = 192.168.29.2, Can't find a valid tunnel group, aborting...!
Jun 08 2007 21:35:07: %ASA-3-713902: Group = 192.168.29.2, IP = 192.168.29.2, Removing peer from peer table failed, no match!
Jun 08 2007 21:35:07: %ASA-4-713903: Group = 192.168.29.2, IP = 192.168.29.2, Error: Unable to remove PeerTblEntry
router# show vers
Cisco Adaptive Security Appliance Software Version 7.2(2)
Device Manager Version 5.2(2)
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 3, DMZ Restricted
Inside Hosts : 50
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
VPN Peers : 10
WebVPN Peers : 2
Dual ISPs : Disabled
VLAN Trunk Ports : 0
This platform has a Base license.
I am attaching the config.
Thanks for your help!
jpginexi Wed, 06/13/2007 - 11:32
Ok, I was able to get this working by not trying to use user defined tunnel groups.
I modified the DefaultRAGroup and used it instead and was able to connect to a tunnel group. Is this a known issue?
However this only got me past Phase1. Phase2 kept erroring with the error "All IPSec SA proposals found unacceptable!".
To get past this error, I removed pfs and switched to use md5 from sha.
crypto ipsec transform-set TRANS_ESP_3DES_MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set TRANS_ESP_3DES_MD5 mode transport
crypto dynamic-map outside_dyn_map 20 set transform-set TRANS_ESP_3DES_MD5
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
Those two changes enabled Phase2 to complete successfully and the tunnel was set up.
l.jankok Sat, 08/04/2007 - 01:48
Thank you very much for the info.
To answer your question why only the default RA group is working:
Since the lt2p/ipsec client doesn't specify a group name the default values of the default RA group will be used. This is the reason why you have to use this group.
Question
I also had some problems with l2tp being that the tunnel was ok but I was not able to access resources from the l2tp client to the remote site throught the tunnel.
