HELP NEEDED! in Removing Delete.csv for DMA .tar file
Jun 8th, 2007
I've been working all day with TAC trying to get the file delete.csv from the .tar file that is generated from the DMA. I've ran into a problem that the upgrade fails, Cisco has came back and said that there is a bug CSCse53281 and I need to remove the delete.csv file from the .tar file. He said that I need a Linux box in order to do it, but I don't have one. I need to know is there a way to get this file out of the .tar, I need to finish this upgrade.
From what I was told that this only affects upgrade from 4.1(3) to 5.0(4). I don't have the 5.1 DVD otherwise I would bypass the 5.0(4)
Any help would be great!
