Point to Point Help
Jun 8th, 2007
I have a new point to point t1 and am having trouble.
I can ping from both routers (both 1800's) to the serial ip of the other but am not able to ping to the lan on the other side. A trace shows it going to the serial interface of the distant router and stopping there.
Here is router A's
ontroller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
interface FastEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$$ETH-LAN$
ip address 192.168.0.245 255.255.255.0
ip access-group Any in
ip access-group Any out
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
duplex auto
speed auto
no mop enabled
interface Serial0/0/0:0
no ip address
encapsulation frame-relay
no keepalive
interface Serial0/0/0:0.1 point-to-point
ip address 192.168.254.1 255.255.255.0
no ip redirects
no cdp enable
frame-relay interface-dlci 100
router rip
network 192.168.0.0
network 192.168.254.0
no auto-summary
ip classless
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip access-list extended Any
remark SDM_ACL Category=1
permit ip any any
logging trap debugging
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
disable-eadi
no cdp run
control-plane
Router B's config
Current configuration : 2967 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname admin1800
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
no aaa new-model
resource policy
clock timezone PCTime -7
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip dhcp use vrf connected
ontroller T1 0/0/0
framing esf
linecode b8zs
ip address 192.168.100.252 255.255.255.0
ip access-group any in
ip access-group any out
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
description $ETH-LAN$
ip address 192.168.0.201 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
shutdown
duplex auto
speed auto
no mop enabled
no ip address
no keepalive
router rip
network 192.168.100.0
no auto-summary
ip classless
ip http server
ip access-list extended any
permit ip any any
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 100 remark SDM_ACL Category=1
i am sure it is something stupid I am doing.
Any help would be welcome
Overall Rating: 5 (1 ratings)
paolo bevilacqua Fri, 06/08/2007 - 14:49
  • Hall of Fame,
    Founding Member
you have a point-to-point T1, hence you don't need frame relay encapsulation. Please configure on both routers::
no interface Serial0/0/0:0.1 point-to-point
ip address 192.168.254.1 255.255.255.0 <- use .2 for the router B
no ip access-group any in
no ip access-group any out
encapsulation hdlc
keepalive 10
And you should be able to ping and connect fine. Also I suggest you quit using SDM because most of the time will do things wrong, or in manner that you don't understand, beside it will hide the configuration logic from you.
thotsaphon Sat, 06/09/2007 - 01:29
  • Gold, 750 points or more
What is device that you used for testing connection?
Can you do show ip route command of both routers?
L.Thot
Edison Ortiz Sun, 06/10/2007 - 12:41
  • Hall of Fame,
    Founding Member
I will be very careful suggesting to remove frame relay.
If he is able to ping the remote-end, the encapsulation is valid and the DLCIs assigned to each end are also valid. A 'show frame pvc' would be ideal before pulling the trigger on that.
Seeing his RIP config may be the suspect here and he may be facing a split horizon issue with RIPv1.
I suggest configuring RIPv2 for classless support.
Matt, can you supply a show ip route from both ends ?
paolo bevilacqua Sun, 06/10/2007 - 16:11
  • Hall of Fame,
    Founding Member
Hello, please check posted config above for serial on router B, there is no IP address whatsoever, I'm not sure what he is pinging, but on my book, interface without IP address == no ip routing on that interface.
Edison Ortiz Sun, 06/10/2007 - 19:14
  • Hall of Fame,
    Founding Member
I did check the posted config but to suggest removing frame relay is a bit drastic without examining the routing between the 2 routers.
As Richard pointed out, this config is not complete and we need more info.
mohammedmahmoud Sat, 06/09/2007 - 01:51
  • Green, 3000 points or more
I agree with every word Paolo has said, but please supply us with a show ip route to find out the reason behind your connectivity issue, and another thing "admin1800" shows inconsistent configuration for Serial0/0/0:0.1, can you confirm this or if it is a typo error.
HTH,
Mohammed Mahmoud.
Richard Burts Sun, 06/10/2007 - 16:18
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I see several issues in the configs as posted. routerA has network 192.168.0.0/24 on interface FastEthernet0/0 and routerB has network 192.168.0.0/24 on interface FastEthernet 0/1. Unless the routers are connected on the FastEthernet segment this is a serious error (or a major typo). As configured routerA will never go to routerB for that network and routerB will never go to routerA for that network since both routers believe that the network is locally connected.
There is also an issue on routerB about the serial interface which does not have an IP address assigned in the config as posted. I note that there is a network statement in RIP for the 192.168.254.0 network which suggests that perhaps omitting the IP address was an oversight. Since the original post says that the routers can ping over the serial interface I would assume that this is just a mistake in posting.
Perhaps the original poster can clarify these issues.
Rick
mattbashara Tue, 06/12/2007 - 08:29
Thanks every one for the help. I have it working now.
If any one is interested I would be happy to post the new config files. Let me know.
paolo bevilacqua Tue, 06/12/2007 - 08:34
  • Hall of Fame,
    Founding Member
If the posts helped, please take a moment to rate them using the scrollbox below.
