Forwarding Call Based on Caller ID
Jun 8th, 2007
I would like to have calls forwarded by a specific external number forwarded directly to an internal extension. Normally all inbound calls go directly to an Auto Attendant, but in this case an automated system needs to call an internal number directly. Any help would be appreciated.
Paolo Bevilacqua Fri, 06/08/2007 - 15:27
Sorry, in this case I must leave the answer to others more proficient on the matter, good luck.
You may want to repost in "IP Telephony" forum, this one is dedicated to video.
lagos Wed, 06/13/2007 - 11:51
If you use H.323 on the gateway, you can use answer-address in your dial-peer.
Good luck,
Cisco Systems
