Defining traffic flow
Jun 8th, 2007
I have a 7206 with 2x FE100 interfaces. I am looking for a way to define within the router IOS how to define which interface defined subnets pass traffic over.
For example I have FE1/0 connect to a LAN, I have connected to this segment. On FE2/0 I have another LAN, 192.168.2/0/24 connected to this segment. I need to be able route all traffic LAN and WAN traffic for segment one, only on FE1/0 and vise versa on segment 2. Can I do this with an ACL applied seperatly to each interface? Also, how can I define a default route ( 192.168.1.x) or ( 192.168.2.x). I have two sperate networks, all internet users, who will need to get out. Each of these interface are going to routed to different network routers.
mohammedmahmoud Sat, 06/09/2007 - 01:31
I guess that you need to do source based routing PBR (Policy Based Routing).
please review these documents and get back if you have further problems:
Policy-Based Routing
Configuring Policy-Based Routing
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
