Cisco works backup error message
Jun 8th, 2007
Hi Friends,
We are using Cisco Works to backup our devices on the network. The backup is automatic and runs every friday. However, i've been observing that backup to 6509 switch fails every week with an error message of "Failed to get the start tag-begin in the configuration ". I am unable to find any information about this error in cisco website. Anyone has any thoughts on this, plz do share. Thanks for your assistance in advance.
Best Regards,
Manoj
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 06/08/2007 - 21:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of RME is this? This may be a known bug.
Manoj Wadhwa Fri, 06/08/2007 - 21:56
Hi Clarke,
This is a LMS2.5 product. Plz let me know if this is a known bug. Is there any link which mentions this bug? Thanks again!
Joe Clarke Fri, 06/08/2007 - 22:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Again, what is the exact version of RME?
Manoj Wadhwa Fri, 06/08/2007 - 23:15
Hi Clarke,
I am not sure how to check the exact version. But i just checked in help and it said "New Features and Enhancements in CiscoWorks Common Services 3.0.3", so i would guess the version is 3.0.3. Does this make sense?
Joe Clarke Fri, 06/08/2007 - 23:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Go to Common Services > Software Center > Software Update. The version of Resource Manager Essentials will be listed there.
Joe Clarke Sat, 06/09/2007 - 09:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Okay, then this is most likely not a known bug. It could be an issue with command authorization, though. Please enable ArchiveMgmt debugging under RME > Admin > System Preferences > Loglevel Settings, then re-run the failing config sync job for the Cat6509, and post the resulting dcmaservice.log.
Manoj Wadhwa Sat, 06/09/2007 - 19:56
Clarke,
I have anabled debugging and re-run the backup again. Can u guide me where to get dcmaservice.log file. Thx
Joe Clarke Sat, 06/09/2007 - 20:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I assume you're running on Windows, so NMSROOT\log\dcmaservice.log.
Manoj Wadhwa Sat, 06/09/2007 - 20:27
Actually it is running on a Unix ... still the log file name will be the same ?? If yes, then i will have to ask some one else to retrieve the log file as i dont have permissions to search for the file.
Joe Clarke Sat, 06/09/2007 - 20:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
On Solaris, the log file will be found under /var/adm/CSCOpx/log/dcmaservice.log.
Manoj Wadhwa Sat, 06/09/2007 - 21:13
Clarke,
Actually i dont have permission to the CSCOpx folder. I will try to request from the server admin and then try to post the logs.
