Limit on adding Logging Servers
Jun 9th, 2007
Hi guys,
Is there a limit on adding more than 3 logging servers on a CatOS Switch. I am trying to add a logging server and I am getting this message "System logging server table is full". Is there a way to increase the limit to add more than 3 logging entries or thats the max it can take. Any tips or suggestions on this appreciated.
TIA
Faiz
Overall Rating: 3 (1 ratings)
mohammedmahmoud Sat, 06/09/2007 - 02:11
  • Green, 3000 points or more
Hi Faiz,
Using the "set logging server ip_addr" command, you can configure a maximum of three syslog servers at any time.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Mohammed Faiz M... Sat, 06/09/2007 - 02:24
Hi Mahmoud,
Thanks for the reply, but thats what I've asked, whether I can add a fourth syslog server IP by any way.
TIA
Faiz
mohammedmahmoud Sat, 06/09/2007 - 02:35
Sorry if my answer was misleading, but i meant that no you can't, and i don't think that it can be increased in any way.
HTH,
Mohammed Mahmoud.
