spremkumar Sat, 06/09/2007 - 03:15
  • Red, 2250 points or more
Hi Mansur
Can you post the output of show process cpu ?
This input will definetely help in identifying the process which hogs the cpu and the steps to be followed or implemented to bring it back to the permissible level..
regds
rootadmin Sun, 06/10/2007 - 03:20
Have attached the CPU load file as requested.
Please go thru and kindly advise.
Thank you
Mansur
rootadmin Sun, 06/10/2007 - 17:43
Yeah..Got what u said...If I disable Spanning tree on all the switches..Would it help?
Mansur
glen.grant Sun, 06/10/2007 - 17:56
  • Purple, 4500 points or more
Do not do that you are playing with fire if you disable spanning tree , this is what prevents you from having loops in your network.
