Restart SNMP on CatOS
Jun 9th, 2007
Is there any way to restart all SNMP processes on a Cat6000 switch?
I have tried "set snmp disable" then "set snmp enable" but it is not resolving my problem.
I am trying to pull SNMP info using a port map utility and it always hangs up on one, specific CatOS switch.
ariela Sat, 06/09/2007 - 06:10
  • Silver, 250 points or more
Please give me a "show snmp"
Andrea
sometechguy Mon, 06/11/2007 - 08:28
SNMP: Enabled
RMON: Disabled
Extended RMON Netflow Enabled : None.
Memory usage limit for new RMON entries: 85 percent
EngineId: 00:00:00:09:00:d0:97:f1:6c:00:00:00
Chassis Alias:
Traps Enabled: None
Port Traps Enabled: None
Community-Access Community-String
read-only removed
read-write removed
read-write-all removed
Additional- Access-
Community-String Access-Type Number View
Trap-Rec-Address Trap-Rec-Community Trap-Rec-Port Trap-Rec-Owner Trap-Rec-Index
ariela Mon, 06/11/2007 - 12:24
Have you already tried "set snmp trap enable all"?
All traps are disabled by default and need to be added to the configuration, either individually or by with the all parameter.
Then check with 'test snmp'
Andrea
