microtel Sat, 06/09/2007 - 11:05
Is ther any combine keys to reset the phone to dafault factory (SCCP)
Paolo Bevilacqua Sat, 06/09/2007 - 15:25
No, the phone must load the files via tftp. If use ccme, it's just a matter of copying files to the router, configute tftp-server statements for all the files, configure load under telephony-service, configure an ephone with the mac-address.
microtel Sun, 06/10/2007 - 06:15
Hello
I follow and do all these steps but without any change. my ip phone is still in SIP!!
Paolo Bevilacqua Sun, 06/10/2007 - 07:35
are you using an external TFTP server or the router ? If the latter, please check again cofiguration including mac-address, and do "term mon" and "debug tftp events". You will see the phone requesting files and which one is failing.
If that doesn't work we can use the method with the text configuration file, and binary utility. But first please confirm the above.
microtel Sun, 06/10/2007 - 07:51
the tftp is on the router,
Here are the display of debug
Jun 10 16:53:55.323: TFTP: Looking for gk000ab8878998
Jun 10 16:53:55.331: TFTP: Looking for gkdefault.cfg
Paolo Bevilacqua Sun, 06/10/2007 - 08:30
Yes you need the "config file and utility" method because your phone is a 7912.
You need to download the utility "bmp2logo.zip" from CCO, area "Cisco Unified IP Phone Client Tools ", note you need to be registered as customer with download privileges (requires a support contract aka smartnet).
You need that also because the V5.x firmware that you mentioned is too old for current CME, only the very latest image 8.0(3) is almost bug free.
Please read:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dde64ef/2#selected_message
Prepare the config file just as mentioned in the thread. copy the binary file to router as gkdefault.cfg and configure with "tftp-server gkdefault.cfg. The phone will then upgrade.
I know it can look complicated but is the only way to do it. Good luck!
