06-09-2007 08:36 AM - edited 03-05-2019 04:36 PM
I have a 2950 cataylst that I need to access via it's IP address, I then want to use SNMP to monitor ports.
I added an IP address to VLAN1 but can't ping it. I have 6 other VLAN in it and have tried ping from the 2950 in hyper terminal but I get nothing. With so many VLANS etc what is it's gateway into the LAN?
06-09-2007 08:39 AM
You need to access the switch from a port that belongs to the management VLAN (VLAN 1 in your case, since you have entered the IP address under interface VLAN1).
[edit] You should be using a separate IP subnet for each VLAN as a best practice, and the default-gateway for this layer 2 switch in this case is the default-gateway for VLAN 1 as VLAN 1 is your management VLAN, and further more this default-gateway will make you able to access the switch remotely and from other VLANs.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
06-09-2007 08:42 AM
Hi Friend,
2950 being a layer 2 siwtch is only capable of having one layer 3 logical interface for management purpose. Now as you added ip address in interface vlan 1 first thing make sure you have atleast one physical interface attached to vlan 1 or a trunk port allowing that vlan.
Then make sure you add a gateway ip address on your 2950 switch pointing to layer 3 device which will route between all your vlans.
Something like this
ip default-gateway
This ip address should be the ip which is configured on your layer 3 switch/router for vlan 1.
Ankur
*Pls rate all helpfull post
06-11-2007 05:13 AM
Hi, when you say I need a physical link into our LAN switch, port 2 which is on VLAN2 (has port 1,2 & 3) has a network cable in to LAN switch.
Should it use this?
06-11-2007 05:46 AM
You need to access the switch from a device connected to a port that belongs to the management VLAN (VLAN1 in your case).
Mohammed Mahmoud.
06-11-2007 05:58 AM
Sorry for these basic questions, how can i tell what is in VLAN 1? A show config shows no VLAN created, just VLAN 1 and it's IP address.
06-11-2007 06:10 AM
By default all ports are on VLAN 1, unless "switchport access vlan x" command is configured under the interface.
HTH,
Mohammed Mahmoud.
06-11-2007 06:29 AM
Just do a " show vlan " and it should tell you that which port belongs to to which vlan. Then if you have any port in the vlan1, you connect your PC to the same port and you should be able to ping the switch and access it.
Please paste the output of " show vlan " and " show config" here and we will be able to help further on this.
HTH,Please rate if it does.
-amit singh
06-11-2007 11:49 PM
Hi, here it is in 2 parts:
core1#sh vlan
VLAN Name Status Ports
1 default active Fa0/21, Fa0/22, Fa0/24, Gi0/2
2 fwinside active Fa0/1, Fa0/2, Fa0/3
3 fwoutside active Fa0/4, Fa0/5, Fa0/6
4 dmz1 active Fa0/7, Fa0/8, Fa0/9, Fa0/10
Fa0/11, Fa0/12, Fa0/13, Fa0/14
Fa0/15, Fa0/16, Fa0/20, Fa0/23
5 dmz2 active
6 VLAN0006 active Gi0/1
7 VLAN0007 active Fa0/17, Fa0/18, Fa0/19
8 VLAN0008 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
2 enet 100002 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
4 enet 100004 1500 - - - - - 0 0
5 enet 100005 1500 - - - - - 0 0
6 enet 100006 1500 - - - - - 0 0
7 enet 100007 1500 - - - - - 0 0
8 enet 100008 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
06-11-2007 11:53 PM
core1#sh conft
version 12.1
service timestamps debug uptime
service timestamps log datetime
service sequence-numbers
hostname core1
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
--More-- interface FastEthernet0/1
--More-- description Management interface
--More-- switchport access vlan 2
switchport mode access
duplex full
speed 100
interface FastEthernet0/2
description Link to *******
duplex full
speed 100
interface FastEthernet0/3
description Link to LAN inside
duplex full
speed 100
interface FastEthernet0/4
switchport access vlan 3
--More-- duplex full
speed 100
interface FastEthernet0/5
description Link ********
interface FastEthernet0/6
description link to ******
interface FastEthernet0/7
switchport access vlan 4
duplex full
speed 100
interface FastEthernet0/8
--More-- switchport mode access
duplex full
speed 100
interface FastEthernet0/9
interface FastEthernet0/10
duplex full
speed 100
interface FastEthernet0/11
description link to ********
duplex full
speed 100
--More-- interface FastEthernet0/12
description Link to ********
duplex full
speed 100
interface FastEthernet0/13
description *******
duplex full
speed 100
interface FastEthernet0/14
description ******
duplex full
speed 100
interface FastEthernet0/15
description ****
--More-- switchport access vlan 4
duplex full
speed 100
interface FastEthernet0/16
description *****
speed 100
interface FastEthernet0/17
description *****
switchport access vlan 7
interface FastEthernet0/18
description ******
interface FastEthernet0/19
description ********
--More-- switchport access vlan 7
interface FastEthernet0/20
description Lin to VLAN4 spare
interface FastEthernet0/21
description VLAN 8 for LAN IP connection
interface FastEthernet0/22
interface FastEthernet0/23
duplex full
speed 100
interface FastEthernet0/24
--More-- interface GigabitEthernet0/1
description To Ground Floor
switchport access vlan 6
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.200.52 255.255.0.0
ip access-group 1 in
no ip route-cache
interface Vlan2
no ip address
no ip route-cache
shutdown
interface Vlan8
no ip address
no ip route-cache
shutdown
ip http server
--More-- !
logging trap warnings
logging facility local4
logging
snmp-server community
line con 0
line vty 0 4
password ****
login
line vty 5 15
password *****
login
monitor session 1 source interface Fa0/1 , Fa0/11
monitor session 1 destination interface Fa0/24
end
core1#
