Serial HDLC Sub Interfaces
Jun 9th, 2007
We have a DS3 point-to-point circuit and want to configure sub interfaces on this line while keeping the encapsilation HDLC. We're only able to pass traffic over the physical interface and not the sub-int. Is this possible or do we need to change to Frame Relay?
Thanks!
Overall Rating: 4 (1 ratings)
mohammedmahmoud Sat, 06/09/2007 - 11:20
No, you can't use HDLC with subinterfaces, only main interfaces, you must go for Frame Relay if you require subinterfaces.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
