06-09-2007 12:31 PM - edited 03-05-2019 04:36 PM
Got kind of a BIG headache on this one. I know it must be simple, but I am just not seeing it.
I have 2 vlans, vlan1 and vlan3. Vlan 1 is a public vlan that connects to the outside world. Vlan3 is non-routable. I configured a PAT. It looked great in the test lab, but is not working in the shop. I can ping the gateway from the switch, but not past the gateway, in the console. Here is a snipet of the config :
interface Vlan1
ip address xxx.xxx.xxx.xxx 255.255.254.0
ip nat outside
no ip route-cache
interface Vlan3
ip address 192.168.32.1 255.255.254.0
ip nat inside
no ip route-cache
ip default-gateway 137.187.44.1
ip nat pool niscpool 137.187.44.105 137.187.44.106 prefix-length 23
ip nat inside source list 1 pool niscpool overload
access-list 1 permit 192.168.32.0 0.0.0.255
access-list 1 permit 192.168.33.0 0.0.0.255
Here is the route table
Gateway of last resort is not set
1.0.0.0/32 is subnetted, 1 subnets
C 1.1.1.1 is directly connected, Loopback0
137.187.0.0/23 is subnetted, 1 subnets
C 137.187.44.0 is directly connected, Vlan1
C 192.168.32.0/23 is directly connected, Vlan3
Any info would be appreciated!!
Poirot
Solved! Go to Solution.
06-09-2007 12:56 PM
This is simply that you don't have a default route, the ip default-gateway should only be used when ip routing is disabled, please configure a default route using "ip route 0.0.0.0 0.0.0.0 x.x.x.x" and it should work fine.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
06-09-2007 12:56 PM
Mohammed Mahmoud.
06-09-2007 12:58 PM
That was it! I knew it had to be something simple that I was just not seeing.
Thank You Very MUCH!!!
Poirot
06-09-2007 01:32 PM
Hi Poirot,
You are very welcomed, i am very glade that we have helped you, and thanks for using the rating system, and please do come back if you have further questions.
BR,
Mohammed Mahmoud.
