06-09-2007 07:28 PM
Hi ,
My comapany had custom portal with domain name as x.mydomain.com ,y.mydomain.com,z.mydomain.com and so on.
Can i use single certificate for all my sub domains.
What will be configuration?
Thanks in advance
Aniruddha
Solved! Go to Solution.
06-11-2007 11:12 AM
Yes you can use a wildcard certificate. You can view the general installation instructions here:
You will just use the same certificate for every subdomain.
Rate if that helps.
06-11-2007 11:12 AM
Rate if that helps.
