The windows-version of spamtowho_418.exe displays this error on every analyzed line:
Use of uninitialized value in concatenation (.) or string at /PerlApp/logfuncs.pl line 1663, <LOGFILE> line 605984.
It doesn't seem to be important, but maybe processing-time could be reduced. :wink: Could someone fix this?
BTW:
I run spamtowho_418.exe with the following batch:
SET mlp="C:\Temp\Path\to\Ironport\mail_logs"
spamtowho_418 -d %mlp% -htmloutput=_test.html -output=_output.txt
