Jon Marshall Sun, 06/10/2007 - 04:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You can use the Pix Device Manager (PDM) which is a web based GUI interface for configuring a pix.
Attached is a link to the PDM page where you can find an overview and Installation/Configuration links.
http://www.cisco.com/en/US/products/sw/netmgtsw/ps2032/index.html
Jon
JORGE RODRIGUEZ Sun, 06/10/2007 - 05:32
  • Green, 3000 points or more
You need to initially console to the PIX
to configure the inside interface and enable http in order to load the PMD(GUI interface).
For that this is what needs to be done to get you up and running with PDM
1-Console to PIX enable mode , config terminal
2- Configure the enable password
enable password password1
3-Enable http server services on PIX
http server enable
4-Configure IP address for the inside interface
Example:
ip address inside 192.168.10.1 255.255.255.0
5- Allow http access to the pix for any system on 192.168.10.0 subnet
Example:
http 192.168.10.0 255.255.255.0 inside
or allow any inside host as http 0.0.0.0 0.0.0.0 inside
6- Allow Telnet access to the pix , same as step 5 but replace http with telnet
Configure your PC TCPIP settings as :
IP: 192.168.10.20
MASK: 255.255.255.0
DG: 192.168.10.1 ( This is your inside PIX interface IP) or leave it blank if in same segment.
Connect your PIX and PC in a hub, if using a switch make sure you're in the same
segment as the pix.
Once both are connected make sure you can ping the pix 192.168.10.1 to ensure IP connectivity.
Then load your web browser and type:
https://192.168.10.1
here are couple of good links for starters:
Getting Started -Guide
http://cisco.com/en/US/docs/security/pix/pix63/configuration/guide/overvw.html#wp1045414
Configuring PDM
http://www.cisco.com/en/US/docs/security/pix/pix63/pdm30/installation/guide/pdm30CH4.html
leungcm Sun, 06/10/2007 - 06:20
thanks for your put. I cannot donwload the PDM software because I haven't any account. Where do I get the demo / eval verison? the old version is welcome as well.
Best regards
leungcm Mon, 06/11/2007 - 06:42
where do I get the software? thanks
Best regards
