IPS regex for a certificate name
Jun 10th, 2007
Using the 4260-IPS I'd like to create a signature using regex that can fire on a specific certificate name. In a sniffer trace I can see the entry as "Name=Grac". I tried using the following regex but it didnt work.
Rodrigo Gurriti Sun, 06/10/2007 - 08:11
Configuration > Signature Definition > Custom Signature Wizard than
Choose TCP as the protocol to inspect >
Click the Single TCP Connection radio button >
Select Other like service type >
Enter signature parameters >
Select your event action
To Regex string filed enter
enter 80 in the Service Ports field
and you should use from service
Or you can clone a tcp string from any other signatures and change the fields
rickellis Sun, 06/10/2007 - 12:50
Thanks rodrigogurrit. I tried this but it does not work. I should clarify that I am trying to fire on SSL(port443) in this case. I adjusted the service port from 80 to 443 but kept everything else the same. What I'm trying to do is fire on the SSL certificate name which I can see in a trace.
Rodrigo Gurriti Sun, 06/10/2007 - 18:03
hummm its a good question because 443 is encrypted and the IPS cannot see what is going on.
mhellman Mon, 06/11/2007 - 06:16
get rid of the backslash, the equal sign is not a metacharacter that needs escaping. What engine are you using?
I'm guessing you're talking about a server certs? I would suggest the "string tcp" engine and make sure you are using the direction "from service".
