06-10-2007 05:12 AM - edited 03-05-2019 04:36 PM
I am confused about something...
Presently, a 7200 router's fa0/0 interface is connected to a L3 hybrid 6509 switch's 2/1 interface. The configs are as follows:
(router)
interface faste 0/0
ip address 10.10.10.4/24
(switch)
set vlan 5
set vlan 5 2/1
(msfc)
interface vlan 5
ip address 10.10.10.1/24
So, by placing the switchport in a vlan and creating an SVI, an L3, routed connection is facilitated between the router and the switch. Correct?
OK, I need to migrate from the hybrid 6509 switch to a fully NATIVE-IOS 6509 switch.
How do I configure the fastE port? The router must exhange routing updates with the L3 switch's eigrp process, as is already the case with the hybrid switch architecture.
Should the L3 fastE switch port be configured like this:
vlan 5
name WAN_xport
interface fastE 2/1
(just like a regular router)
OR
should I create the vlan SVI interface and then simply place the switchport in the vlan as you do in a hybrid switch (see below):
vlan 5
name WAN_xport
interface vlan 2
interface faste 2/1
switchport
switchport access vlan 5
switchport mode access
Solved! Go to Solution.
06-10-2007 05:41 AM
Hi Andrea,
No apologies my friend :) This happens to me a lot ... it doesn't matter you solve the problem or me, as long as we are helping the original poster.
BR,
Mohammed Mahmoud.
06-10-2007 05:25 AM
You can go with any of both approaches, according to your topology, if you require more ports to use this VLAN and have an SVI interface to route this VLAN traffic go with the second solution, while if you require only point to point connectivity between the switch and the router go with the first solution.
HTH, pleas do rate all helpful replies,
Mohammed Mahmoud.
06-10-2007 05:33 AM
both configurations work, but the first in your design could have more sense. If you need just a routed port, the first is enough. If you would that router will be the vlan5 default gateway, so use the second (without SVI if you please, that's not necessary).
The difference between configurations is: the first is a routed port, so consider that just a L3; the second is a switchport (in your case in access mode, but could be have more sense in another scenario in case of trunk mode, carrying more vlans), so a L2 port that has a L3 virtual interface corresponding the vlan in access.
more infos about difference between routed port and SVI:
Andrea
[edit] I'm sorry, Mohammed, I've seen your post late
06-10-2007 05:41 AM
Hi Andrea,
BR,
Mohammed Mahmoud.
06-10-2007 05:45 AM
correct ;)
thanks Mohammed
Andrea
06-10-2007 06:20 AM
Thank you to the both of you.
Mohammed, you hit the nail on the head. Not only did you answer the question, but you preempted me asking the follow-up, which would have been regarding the case of adding more router connections in the same vlan. :-)
In fact, there are several router connections that the client has placed in the same vlan, so I would use the second scenario.
Andrea, thank you for your input and the link. I will check it out further.
