Clearing sessions on CSS11501
Jun 10th, 2007
HI,
If i run
(config)# zero service total-connections
will my all connections on CSS will be resetted to zero or the current conncections will only be ressetted to zero.
I want to reset total local connections to zero.
Total Local Connections: 22893465
Current Local Connections: 16
Total Connections: 22893465
can some body help me in doing this. this would be great help.
regards
Mukesh
b.hsu Fri, 06/15/2007 - 10:27
By default, access to the CSS user database is not restricted. Nonrestricted access means any user with SuperUser privileges (local user, administrator, or technician) can:
?Create, modify, or delete usernames (user database entries)
?Clear the CSS running-config file
You can use the restrict user-database command to restrict the CSS user database to CSS users who are identified as either an administrator or a technician.
To restrict modification of the CSS user database, enter:
(config)# restrict user-database
To remove restrictions for modifying the CSS user database, enter:
(config)# no restrict user-database
