CCIE VOICE lab switch?
Jun 10th, 2007
I would like to put together my lab and already have some of the parts I need; CM4.2.3 and Unity 4.2.1, IPCC Express. The current switch I am using is a 2924 that doesn't support LAN QOS syntax. Can someone suggest the least expensive lab switch for my studies, hopefull one that will support POE as well? I was looking at one of the models in the Catalyst Express series (WS-CE500-24LC ), but I don't know much else about the switch.
-Shikamaru
Chris Deren Thu, 06/14/2007 - 14:05
The cheapest one as well as the actual one used on the exam will be 3550. Check it out on ebay.
By the way, the current exam covers CM 4.1(3), and Unity 4.0(5). I seriously doubt it will ever cover CM 4.2, my guess is that the next update will be CM 5.X.
HTH,
Chris
shikamarunara Thu, 06/14/2007 - 14:34
That's interesting. The 3550 reached EOL a year ago (which is good news since EOL switches are cheaper to aquire.) Thanks much for the info, cderen.
-Shikamaru
