AXL with VMWARE doesnt work
Jun 10th, 2007
Hi people,
I am trying to test axl applications in a callmanager (ver. 5.1.1.2000-2) running inside a vmware. The PC is an Windows XP Pro, core2duo with 2G memory.
I have tried to run the java example illustrated in the Developers Guide for Release 5.0, but it returns nothing, in fact, returns special caracters "".
I also have tried with php and returns the same thing.
The java code is attached here.
Is my code correct?
The PC is running with IIS, PHP 5 and Netbeans 5.5 with JDK 1.6.
The PC has IP 10.1.1.100, the callmanager inside the vmware has IP 10.1.1.1. The files are in the PC, and when I call them, I got the error above described.
Any one got the same problem?
Can any one post a correct example?
Thanks.
Sascha Monteiro Mon, 06/11/2007 - 13:24
You cannot just open a socket to a secure connection (HTTPS)
have a look at the axlsqltoolkit, it has an example of how to connect.
toshiosakata Wed, 06/13/2007 - 09:21
Hi Monteiro,
Finally it works.
Is possible to update an registry ou only query the database?
Some thing like:
update device set description='abcde' where pkid='089d9f80df98fdf'
I have triend this and I got the following response:
http://schemas.xmlsoap.org/soap/envelope/">
SOAP-ENV:Client
Method only for queries
http://www.cisco.com/AXL/1.0">-79750
executeSQLQuery
Thanks!
Sascha Monteiro Wed, 06/13/2007 - 13:28
I am not sure how you can update via executesqlquery
(you couldn't in cm4.x)
It's better to do a updatePhone via AXL
stephan.steiner Thu, 06/14/2007 - 23:57
In CCM 5.x and higher you can use executeSQLUpdate to update the database (insert, update or delete) - there is no equivalent in CCM 4 and lower.
toshiosakata Fri, 06/15/2007 - 04:11
Hi Stephan,
You are right!
The axlsqltoolkit example for CCM 5.1 works with executeSQLUpdate.
Thanks!
Also thanks to Monteiro.
