CRS Editor 4.0.4 GetDigitString Input Timeout Limitation
Jun 10th, 2007
I've tried to setup initial timeout and inter-digit timeout to be more than 8 seconds, but below exception throw out:
com.cisco.expression.ExpressionVetoException: result is out of bound; expecting maximum of: 8.
Anyone encounter similar problem before?
carlosmoraeveris Thu, 06/14/2007 - 07:25
For the initial timeout there's a mid'solution. Try to concatenate two prompts: the one you have in the get digit and another 2 seconds long mute prompt. The 8 seconds initial timeout plus the 2 of the mute prompt make an initial timeout of 10.
ooclappdev Thu, 06/14/2007 - 21:41
Thanks for your reply.
May i ask is this the limitation for the CRS editor?
carlosmoraeveris Mon, 06/18/2007 - 02:59
As far as I am concernned I think so. I encountered no possibility to get an initial timeout of 10 seconds in any other way with CRS editor.
