VoiceT1 CAS - Loop start
Overall Rating: 2 (1 ratings)
Hey, thanks for the links the last one was very informative.
It only tells me that I can use either
ds0-group 1 timeslots 1-24 type e&m-fgb (OR)
ds0-group 0 timeslots 1-24 type e&m-fgb dtmf dnis
or other types, but I do not know what I need to use for LOOP START.
Is there a particular ds0-group TYPE that I need to use???
Joel
paolo bevilacqua Mon, 06/11/2007 - 06:25
  • Hall of Fame,
    Founding Member
Is the T1 line from a telco switch, and the router "pretends" to be 24 telephones ?
If so, type should be fxo-loop-start.
paolo bevilacqua Mon, 06/11/2007 - 06:58
  • Hall of Fame,
    Founding Member
If telco has given to these lines one or more numbers that you can call from any telephone, then yes these are fxo-loop-start.
Note this is a type of singaling that can give you problems because of lack on disconnect supervision (among other things), so if you want things to run really smooth and easy, ask telco if they can make the circuit to be ISDN PRI instead.
