ASA5510 Radius not work
Jun 10th, 2007
I followed technical note ( to configure remote Radius authentication, but got following error message when try to verify the Radius from firewall:
"ERROR: Authentication Server not responding: No error"
any suggestion?
Many thanks~!
anandramapathy Sun, 06/10/2007 - 22:44
Are you able to ping the server from the PIX ?
are you able to verify the ports on the radius server ports 1812,1645
swapnendum Sun, 06/10/2007 - 22:53
also make sure the key on both sides are same. In case you are using a self created network devices group in ACS, make sure you are using the group key in NAS and not the device key. Group key will take precedence.
alex.chung Sun, 06/10/2007 - 23:14
i can ping that radius server from ASA, how can I verify the posts from radius?
i can sure that the shared secret key is same as the key in aaa- server firewall.
m.sir Sun, 06/10/2007 - 23:37
Can your try test aaa command????
test aaa-server authentication server_name
alex.chung Sun, 06/10/2007 - 23:40
yes, i did tried test aaa command, but got the above error message in ASA.
