Question on CSS cookie sticky
Answered Question
Jun 10th, 2007
Hi everyone,
I have a question about CSS cookie sticky.
- Server issues the following cookie string to the client and it is fixed to 18 bytes.
Set-Cookie: JSESSIONID=aaabbbcccdddeeefff; path=/
- Client embedded the following cookie string in the subsequent HTTP header.
Cookie: xx_user_id=ZZZZ03; com.dummy.xyz.session.cookie=|user|pc|ja|Shift_JIS|default||yellow|/oooo/default.portal|; JSESSIONID=aaabbbcccdddeeefff
* Note that I made cookie information suitable as example.
There is the cookie string (JSESSIONID=aaabbbcccdddeeefff) issued by Server in the HTTP header from client but that cookie string (JSESSIONID=aaabbbcccdddeeefff) is located following the cookie string that the client made by oneself at the end of cookie string. And the cookie string and the length of cookie string that client made by oneself might change so the total length of cookie string also might change. It means I can not clarify the total length of the cookie string.
In this situation, I want CSS to stick with cookie string "JSESSIONID=aaabbbcccdddeeefff".
The characters of string located following the "JSESSIONID=" (in this case, "aaabbbcccdddeeefff") might change but it is fixed to 18 bytes. The total length of cookie string is 141 bytes in above mentioned example.
So I informed customer to configure the following parameters to get CSS done cookie sticky for above mentioned cookie string. CSS software version is sg0750303.
owner test
content testsv-tcp80
add service testsv1-tcp80
add service testsv2-tcp80
advanced-balance cookie
 string range 1 to 200
string process-length 18
url "/*"
redundant-index 1001
protocol tcp
port 80
vip address xxx.xxx.xxx.xxx
active
However CSS was not able to treat the above mentioned cookie correctly which means the subsequent HTTP request was not stuck (persisted) to same server.
I do not understand why CSS cookie sticky did not work correctly with this configuration.
Then customer configured CSS with the following parameters to get CSS inserted cookie string and, of course, the result is OK that is CSS could stick the connection to same server.
owner test
advanced-balance arrowpoint-cookie
url "/*"
protocol tcp
port 80
active
Has anybody experienced similar thing ?
Could you please let me know if you have any comment, information
Your information would be appreciated.
Best regards,
Correct Answer by Gilles Dufour about 9 years 8 months ago
the CSS does not learn dynamic cookie.
You can match a fixed string inside a cookie and pre-define which server to use with that specific string.
That's why your solution did not work.
Arrowpoint-cookie is a better solution and easier to implement.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Mon, 06/11/2007 - 00:58
Gilles.
snakayama Mon, 06/11/2007 - 01:37
Thank you very much for your reply.
I understand what "dynamic cookie" means and CSS does not learn dynamic cookie.
I am going to configure CSS with arrowpoint-cookie.
Best regards,
