Maximum spanning tree instances
Answered Question
Jun 11th, 2007
is there an IOS command to see the max. spanning tree instances on a Switch??
I found the description only on the Datasheets on Cisco.com...
Are the max. STP instances only Hardware related or also IOS?
Thanks and regards,
Thomas Feichter
Correct Answer by ariela about 9 years 11 months ago
3560: 128 (or 16 MST)
6500: 16 MST
2950: 64
Andrea
Overall Rating: 3 (1 ratings)
royalblues Mon, 06/11/2007 - 04:13
  • Green, 3000 points or more
There is a limitation on the number of instances of STP that a switch can handle.
The Catalyst 2912 XL, Catalyst 2924 XL, and Catalyst 2924C XL support only 64 STP instances and 64 VLANs. All other Catalyst 2900 XL switches and all Catalyst 3500 XL switches support 64 STP instances and 250 VLANs.
The 3750 switches support 128 STP instances.
Ensure that the total number of logical ports across all instances of STP for different VLANs does not exceed the maximum number supported. If you exceed these STP instance recommendations, the switch exhibits high CPU utilization
HTH, rate if it does
Narayan
thomas.feichter Mon, 06/11/2007 - 04:30
you know also how many instances supports the Cat 3550,3560,6500,2950?
Thomas
Correct Answer
ariela Mon, 06/11/2007 - 04:52
  • Silver, 250 points or more
6500: 16 MST
2950: 64
Andrea
