SIP Calling Info Problem
blrnetwork
I have C2600 with 12.3-7.T6 IP Voice and i have configured sip on this router
sip-ua
calling-info pstn-to-sip from number set 600
When i dial any extension via this router i don't get calling number as 600 in my CCSIP Calls Debug, but i get the actual numbers (extensions). Where i am doing mistake.
I tried putting a translation profile and rule
translation-rule 1 /*./ /600/
After this it works perfectly alright.
Sarva
paolo bevilacqua
Another simpler method, in the outgoing DP, configure "clid network-provided 600".
The command is
'clid network-number 600'
I tried this and working fine. But the mystery of not forwarding the calling number of 600 even after defining the same in sip-ua is still there.
Try with "no remote-party-id".
I'm actually happy as I got almost right from memory for the other command. Consider there are thousands.
