06-11-2007 05:14 AM - edited 03-05-2019 04:37 PM
If I go into my 2960G through the web interface and check the configuration it shows diiferent settings on some of the interfaces than if I go in and look at my running-config in a console session. Is this normal and which one should I trust?
06-11-2007 06:55 AM
Can you illustrate the differences ?
06-11-2007 07:34 AM
If you go into the GUI and veiw the interfaces it will show some as 10/Full, but if I view them by pulling the running config it will show them set to 100/full.
06-11-2007 07:37 AM
Interesting, I suggest trusting the running config. It could be a bug within the GUI.
You can verify what speed/duplex the interface is running by issuing the 'show interface' command.
06-11-2007 09:28 AM
Verify with show runn and then double check it by using the show interface status command .
