We recently installed an Cisco 876 on an German ADSL2+ Line and it worked fine for the first few days. After that the Router startet loosing the ADSL-Connection once or several times a day. In order to get the connection up again we needed to reset the router which then brought the connection up again until he lost it again.
Is that a known problem we can do anything to change it. I remember when we started using the Cisco 836 Routers in the very beginning we had alike problems which got solved by a newer Firmware for the router. Maybe this is the same as the 876 is quite new.
I attach the routers config maybe the reason for the problem lies therein.
Currently the Router is running IOS 12.4(6)T7
Thankx in advance for any help. :-))
Dirk
