06-11-2007 07:13 AM - edited 03-13-2019 04:12 PM
I am setting up an ATA 186 for use with a FAX machine. Which configuration is best to use for this? Should I configure for SCCP, or MGCP?
06-11-2007 12:49 PM
One that you didn't mentioned, H.323. By general consensus,it's the protocol that works better.
06-11-2007 01:20 PM
What are the determining factors in selecting the signaling protocol?
I am running CM4.1(3)sr4d. All of the gateways on my network are configured for MGCP. I've put the ATA on the network already using SCCP and it was as easy as adding a new phone. I can't seem to find any information indicating why one protocol would be better than the other.
06-11-2007 02:20 PM
perhaps not an explicit document, but the experience of many (admittedly, not including myself yet), is telling that H.323 is the preferred protocol. You can try reposting the question in "IP telephony" forum where it will have more visibility.
06-11-2007 01:26 PM
the main thing is that you need to configure Fax PassThrough in your ATA and PSTN gateway device.
have a look here;
