CISCO CCM 5.1.2 & CUPS Server
Jun 11th, 2007
The connection between CCM & CUPS is working. The troubleshoouting tool from the CUPs did not show any failure.
But i cant see the status from the telephone on the presence client. I can only see the status if the user i logged on or the user has not used his computer for some time.
If i pick up the phone, the window in the CUPC opens but i cant se the status in the CUPC.
I can dial from the CUPC, this also works fine.
I can add other users to my profile, but i cant see their phone status on my CUPC.
Overall Rating: 5 (1 ratings)
wesleyv Wed, 07/04/2007 - 01:18
Hi, anyone have feedback on this issue? I'm running into the exact same thing?
Any suggestions would also be appreciated
twiesboeck Wed, 07/04/2007 - 01:22
There are no changes it is still the same problem on my system
Regards Thomas
jconi Wed, 07/04/2007 - 12:01
You need to enter something (cisco for example) in the "Associated PC Digest Credentials" parameter of the End User CCM configuration.
Strange but it worked for me.
wesleyv Wed, 07/04/2007 - 23:25
I also just saw that, thanks for the response - weird, I used 12345 and the whole thing just came to life. Is there any documentation on the "why" question?
jchorlton Wed, 09/12/2007 - 12:43
I think I have the same problem.
Do you just have to enter something on the End User logged into the Communicator or is it every user?
